If you have a loose fuel pump connection, turning a certain direction or going up/down a hill and it causing the same issue. Lack of fuel would cause your car to shut off. Other things that could cause that are a corroded temp sensor connector and loose cas connector.
Cheers, JBrobst
"A life spent making mistakes is not only more honorable, but more useful than a life spent doing nothing." George Bernard Shaw
